Bolero to Colombus
Evening guys
Looking at swapping my units over as I want built in satnav and other goodies that come with the bolero.. my questions are do I need a new bluetooth module?are the wiring the same and what GPS antenna to I need
Thanks Kelby
The wiring on both is the same. I was able to use the same Bluetooth module when I switched from Bolero to Columbus. I think the GPS antenna is widely available (mine came with the unit) and I've put it behind the glovebox.
You'll need a new trim as well as the Bolero & Columbus are different shapes.
So is the gps antenna part of the normal aerial or separate unit again? I thought wiring was the same just not sure whether my Bluetooth unit will also work
Bluetooth willwork the same, as long as it's all coded when you finish the install. The GPS antenna is seperate, and unless your car had sat nav when it left the factory then you won't have a GPS antenna. They're about a fiver off ebay.
kjaybVrs - the bolero doesn't have sat nav. You'd need the Columbus for that.
I think looking at the steering wheel it has the voice button so fingers crossed be ok..
Good right up looks very easy job so hopefully wI'll be easy to switch..
I will have a proper look again tomorrow only drive car on weekends so easy to forget what on there.when I've done research into it looks like mine does but will find out some more
