S3 Product Spec Codes.
Does anyone have or has access to a  list of the product spec codes for a S3. My S2 had in the Service Handbook, a sticky label which had a list of codes which detailed what exactly was fitted to the car.
I would like to ensure that when eventually my S3 arrives, I can check it has all the bits & pieces that I asked for.
Hoping someone can help.
TIA
Kronik99uk
Here are the options I ordered:
19” Phoenix anthracite alloy wheels (PJ8) £650
Temporary space-saver spare wheel (PJA) £100
3 spoke leather MFSW with DSG paddles (PLE) £95
Smart light assist with Lane assist and BSD (PNG) £100
Wi-Fi and Phone box (PT5) £250
Heated windscreen washer nozzles (9T1) £50
Crew protection assist (7W2) £150
Rear-view parking camera (KA2) £300
Unblinds for rear window and rear side windows (3Y3) £250
OK - here goes. I managed to get the build sheet for my L&K  photographed when it was still less than 24 hours off the transporter - it was taped to the boot floor.
This meant I could then check that what I ordered had at least been built in to the car. First worry - very few of my option codes were listed - only a couple. Then I decoded the whole sheet using the site below, and found that in fact all my options WERE included, but no longer with the codes used in the ordering process. This was very helpful: http://vag-codes.info/  - note you can download all the known codes as well as use the online lookup.
I was also expecting to find the sticker in the handbook but didn't have time to locate it in the car.
Have a look at this attached picture of it, with my markup:
TIA
Kronik99uk
If you go on the configurator on the SUK site and put your spec together, then select the Save as PDF option (it's called something like that anyway :) ), the resulting document lists everything, including all the option codes.
What I have discovered is that the option codes are within the brochures however they are in white font i.e. search on PJ8 in brochure and it will show a block after the description of the option.  I have not found a quick way to copy them but a pdf to text application would probably work. To decode singular options then copy block after description and paste into text editor and change font colour. Hope it helps.....
If you have a license of Adobe Acrobat you can export the options pages, select all text, change all text colour to black.
Absolutely what I did. But you might find that the codes listed when the car is delivered to you are not as obvious - some of them are the same as the configurator's ORDER option codes but not all of them. So you can use http://vag-codes.info/  to double check.
Once again, thanks for all the prompt info, I will use http://vag-codes.info/ to check against ( if there is indeed a label in the service book.)
What a wonderful source of info this forum is, any info provided at the drop of a hat with humour and good grace. Take a bow all you list members.
On a final note has there been many TSI 220,s arriving on these shores??.
Still waiting for my TSI 220.
Hope this is useful?
S, SE, SE L, L&K
Wheels and suspension
17" Helios alloy wheels with anti-theft wheel bolts and Super ROWI tyres Only available on 1.4 TSI and 1.6 TDI
PJD
17" Stratos alloy wheels with anti-theft wheel bolts
PJ2
17" Stratos alloy wheels with anti-theft wheel bolts and Super ROWI tyres Only available on 1.4 TSI and 1.6 TDI
PJE
17" Zeus alloy wheels with anti-theft wheel bolts
PJ3
18" Zenith alloy wheels with anti-theft wheel bolts
PJ4
18" Modus alloy wheels with anti-theft wheel bolts
PJ5
18" Pegasus alloy wheels with anti-theft wheel bolts
PJ6
19" Phoenix alloy wheels with anti-theft wheel bolts
PJ7
19" Sirius alloy wheels with anti-theft wheel bolts
PJ9
19" Phoenix anthracite alloy wheels with anti-theft wheel bolts
PJ8
PJA / PJB
Drive mode selection Allows the driver to adapt the car’s behaviour to their preference or needs. Four driving modes
are available; normal, sport, eco and individual (which allows the driver to configure customised settings)
PFD-
Dynamic chassis control (DCC) Allows the driver to adapt the chassis properties to their preference or needs.
The system continuously evaluates and responds to various driving situations, adapting the damping and steering
characteristics. The available modes for DCC are normal, comfort and sport. Also includes drive mode selection
PFC
Exterior
Bi-Xenon headlights, AFS and LED daytime running lights with integrated headlight washers
PN0
Rough road package Includes engine guard and underbody stone guard. Ride height is increased by 15mm.
Only available in combination with 16" or 17" alloy wheels
PF1
Sunset glass
4KF
Hatch only
Rear-window wiper
8M1
Interior
3 spoke leather multifunction steering wheel with DSG paddles Only available in combination with DSG transmission
PLE
Alcantara/leather upholstery*
PL2
Leather upholstery*
PL1
Lumbar support for driver and front passenger
PK2
Electrically adjustable front seats Includes lumbar support and auto dimming door mirrors with memory function PB3 ( + PW1 on SE)
Front passenger seat adjustment from rear Allows rear passengers to control the adjustment of the front passenger seat.
Only available in combination with electrically adjustable front seats
4V2
Heated front seats
4A3
Heated front and rear seats
4A4
Ventilated front seats Only available in combination with electrically adjustable front seats
PHC / PHB on L&K
Dark aluminium look inserts
5MC
LED package plus Includes LED front reading lights, door handle illumination, footwell illumination in front and
rear and illuminated vanity mirrors. Also includes decorative ambient lighting strips on the dashboard and front
PNF + 5XH
and rear doors which can be set in three colours: warm amber, green or blue
Fold flat front passenger seat
PKJ
Rear backrest release from boot
UK3
Sunblinds for rear side windows
3Y4
Sunblinds for rear window and rear side windows
3Y3
Textile floor mat set
0TD
Boot net programme
6M3
Smoker's package Front ashtray and lighter
9JB
Waste bin in door panel
3LE
Hatch only
Sunroof
PH9
Estate only
Panoramic sunroof
PH0
Variable boot floor Not available in combination with space saver spare wheel
3GN
Partition net screen
3CX
Retractable parcel shelf Automatically retracts when the boot opens
3U7
Safety and Security
Hill-hold control Standard with DSG transmission
UG1
ISOFIX on front passenger seat
3G1
Crew protection assist and rear side airbags Senses when an impact is imminent and closes windows and sunroof
to protect the passengers from objects entering the car as well as tightening the seatbelts ensuring occupants
are in the safest possible position
 PE2 + 7W2
Entertainment and Communication
Amundsen touchscreen satellite navigation system SD card-based navigation with 6.5" colour TFT touchscreen
RAC
Columbus touchscreen satellite navigation system with integrated Wi-Fi HDD-based navigation with 8" colour
RAG + PT4*
TFT touchscreen, DVD drive and an internal SIM card slot
Bluetooth®+ with Phone box By placing a mobile phone in the tray in front of the gearshift lever the strength
of phone signal can be improved by up to 20%. This provides better sound quality during phone calls and helps
to improve phone battery life
PT1 / PT5 on SE L Executive and L&K
Premium WLAN with integrated high-speed LTE internet † Includes SIM card slot and rSAP profile compatibility
to provide high-speed LTE internet. Only available in combination with Columbus satellite navigation system
PT2**
Media Command Allows wireless control of selected functions of the Columbus satellite navigation system using
a mobile device via a wireless Wi-Fi technology. It is possible to access the following functions: media, navigation,
radio and audio settings. The Media Command application is available from app stores RA1
CANTON sound system Tailor-made for the Superb, this sound system delivers a total output of 610W and features
a 10 channel digital amplifier and 12 speakers: 6 front, 4 rear, 1 in the dashboard and a 200W subwoofer in the boot.
Includes 12 pre-set sound profiles, vehicle noise cancellation and 3D surround sound. Delivers Dolby 5.1
surround sound when combined with Columbus satellite navigation system RA3
SmartGate Uses Wi-Fi connection to send selected vehicle data to a connected device. Special mobile apps are
available which allow you to analyse driving data and performance to find out more about your driving style.
Examples of data available include vehicle speed, engine revs and g-meter. The SmartGate applications are
available free of charge from app stores EI9
TV Tuner Displays DVB, DAB and DMB-DTV broadcast formats whilst the vehicle is stationary. Only available in
combination with Columbus satellite navigation system QU1
Colour Maxi DOT trip computer
9S6
Driver Assistance
Rear parking sensors
7X1
Front and rear parking sensors
7X2
KA2
Park assist Parks the car in parallel or bay spaces. Includes front and rear parking sensors
PPA
Lane assist and Blind spot detection Lane assist is a camera-based function which is designed to keep the vehicle within
its lane and, if necessary, alert the driver of an unwanted lane change. Blind spot detection uses a radar to prevent the driver
from failing to notice a car in the blind spot behind or beside the car and, if necessary, provide a warning signal to
the driver in the outer corner of the wing mirrors. Only available in combination with electrically adjustable front seats
PWC
Light assist with high beam control Assesses the light conditions and traffic situation and automatically
switches on and off the high beams. Only available in combination with Bi-Xenon headlights
PNC***
Smart light assist Uses the multifunction camera to detect when to switch between low and high beams automatically
and prevents other drivers from being blinded by the vehicles lights. Also adds further decorative illuminated LED strips
to the headlights for a more distinctive look. Includes Lane assist and Blind spot detection. Only available in combination
with electrically adjustable front seats and Bi-Xenon headlights PNG
* Order PT5 if Phone box option is also required
**Order PT3 if Phone box option is also required
*** Order PWZ if Lane assist and Blind spot detection are also required
Travel assist with traffic sign recognition and display Uses the multifunction camera to recognise and display traffic
signs on the Maxi DOT and navigation displays. Only available in combination with a satellite navigation system
PWD
Cruise control with speed limiter
8T6
†High-speed LTE internet is activated by inserting a SIM card into the slot in the glovebox, or connecting a smartphone via the rSAP profile. Passengers can then connect to the
Superb's Wi-Fi hotspot and browse the internet wirelessly on their individual devices.An external data source is required to enable the Wi-Fi hotspot services. Only available for
mobile phone or SIM card contracts which include a data option with the use of LTE, if LTE usage is required. Usage will only be available within the coverage of the mobile phone
network; there may be additional costs for the use of these services (charges and billing correspond to the mobile phone or SIM card contract). Due to potentially high data
volumes, a contract including an unlimited or high usage data plan is strongly recommended.
Driver Assistance
Tri-zone climate control Allows three autonomous thermal comfort zones to be set: driver, front passenger
and rear passenger. Temperature range available is 16 - 29.5 °C and the rear temperature setting can be
deactivated in the infotainment system when not in use
9T1
Heated windscreen Designed to quickly defrost or demist the windscreen. A thin metal-coated layer is used
throughout the glass area and heats whilst the engine is running. This also reflects heat when warm outside
to help keep the interior cool PKV
KESSY - Keyless entry and start system
Allows the car to be locked, unlocked and started with a button as long as the sensors detect the key is with the driver
PK7
Electrically operated boot Enables the boot to open and close at the touch of a button; via the key, central panel
or boot handle. The top position of the boot lid can also be adjusted to suit individual preferences
4E7
Virtual pedal Enables touch-free boot opening via a motion sensor under the rear bumper. If the system identifies
the authorised key and detects the 'kick' motion, the boot will open. Includes electrically operated boot functionality.
PK9
Only available in combination with KESSY
Swivelling tow bar The tow bar can be easily released from the boot and folded away after use. Includes preparation
of the following vehicle systems for optimised operation whilst towing: alternator, battery, fan and cooling system
1D4
Service and Warranty
Extended warranty Total 4 years or 80,000 miles
EA5
Extended warranty Total 5 years or 100,000 miles
EA6
Service Plan Total 3 years or 30,000 miles
SP3
  • 3 years later...
Just a word of warning for future buyers. I wanted Smart light assist and two things lead me to make an error in ordering which ended up getting me only Light assist instead of Smart light assist.
PWZ option was around 250 GBP more expensive than PNG option in my market (Croatia) which lead me to doubt if they named it correctly in online configurator as it didn't seem logical that Light assist + Lane assist + Blind spot detection can be more expensive than Smart light assist + Lane assist + Blind spot detection. I asked the same question to the dealer and got them confused as well. Then I went on to consult the Internet and found the snippet below based on which I wrongly concluded that PWZ is the code for Smart light assist + Lane assist + Blind spot detection. It turns out that mark *** is ties it to PNC code (also marked with ***) so PWZ is actually Light assist + Lane assist + Blind spot detection and it was just unluckily listed right below Smart light assist in this printout.
Summary:
PNG = Smart light assist + Lane assist + Blind spot detection
PWZ = Light assist + Lane assist + Blind spot detection
And, illogically, PNG is cheaper than PWZ.
So, it turns out that I paid 250 GBP for a life lesson of "Don't act smart" "Assumption is the mother of all f*** ups".
PNC***
