Door loom many problems.
So been having problems with my drivers door on my mk1 Octavia vrs I've replaced the door module, wiring loom, window regulator- with control board, checked fuses but still the remote central locking won't work, drivers window works for a bit then stops non of the other door electrics work either. I wonder if anyone has any suggestions I'm running out of ideas.
Have you checked the part number on the replacement window motor as if not the same it wil need coding in?
