Fabia vrs rear brake disc and pad change.
Hi all,
I was just wondering when changing the rear discs and pads does the car have to be park or neutral with the handbrake on or off? Bit of a new one on me. Used to doing manual cars. First time with an auto.
If you put it on Park the front wheels will not move. Locked.
Best chock the front wheels as well if jacking up the rear,  and hand brake will need to be off when doing the rear.
Excellent. I was thinking that but thought I best check up. Cheers mate.
do they really need changing? I have done 52k, and numerous track days every year, (have to replace front discs and pads every year)  and my rear brakes are about 50 % worn....
It's worth a mention just incase you didn't know but the calipers don't push back, you need the special tool for it. I made that mistake when doing mine, luckily I had a friendly garage nearby who borrowed me their tool.
Edited by LGM
Yeah. Had two new tyres fitted a month ago, the guy checked the pads and said they were registering red on his gauge. Also the discs are heavily corroded. And for £50 it's cheap enough to do.
LGM yeah I've got a wind back kit cheers. I'm guessing they are clockwise to wind back.
My dealer wanted 250 for rear discs and pads - aye, right!
That's extortion. Parts come to just under £50 from euro car parts. Never had a problem with using them before.
Skoda National Pricing offers are rather expensive.
Near £500 for front and rear Discs and Pads done by them.
£100 Parts including VAT,
so you are paying near £100 including VAT per corner for their Labour.
Never a 4 hour or even a 2 hour job.  But that is business, and skills, & profits and overheads,
if you can DIY then sorted.  Or someone more realistic in pricing.
http://skoda.co.uk/owners/service-and-maintenance/simply-fixed
sorry, is this just for the rears or is this the case for the front too? I've done 52k on my front brake pads so far and even though they should last until it's next service in 4-5000miles, I'd ideally like to replace them myself soon. On other cars I've had it's been an easy job, but i'd buy the tool to do it if this is the case.
The front Pistons just push back into the housing as the handbrake mechanism doesn't act on them. the front Pistons just move in and out. Where the rear Pistons basically ratchet out.
Abut bit off topic but I did my rear wheel bearings and took me less than 15 minutes to do it, all four wheels back on the ground
Great, thanks very much! I've ordered some standard ferodo pads from 'mister-auto'. Apparently parts come from Belgium but they were only £21 odd and £30 on Amazon. So I'm hoping they're the real things and will be good. Thought I'd give them a go as they were no more than other brands on ECP.
Edited by MillsyVRS
I like the Ferodo Pads and Discs.   Work well and a whole set for the vRS is only £136 or so.
How much are the discs? And any part numbers?
Edited by MillsyVRS
Sorry no Invoice to hand,
The Motor Factor just hands over 4 discs and 8 pads and a Oil filter and the total with VAT is £140.4.
