Instrument Cluster differences ?
I'm looking at changing my instrument cluster due to a minor issue with my existing clock set, I currently have fitted :
Original : 1Z0920912H   ( I know the existing coding etc)
Possible replacement : 1Z0920912D
Difference only being the letter D anyone know what this signifies or how it differs.. ?
OR anyone got a set in the back of their garage ?
Thanks in advance.
You need to be careful pre facelift and facelift as the clusters are not compatible, they use different protocols to talk to the car and have different wiring.
Ah I assumed that it was a pre-facelift.
Good point.
index H means FAZIT4 security, there is no PIN and normally can be this cluister installed only with online acces to audi server or by someone who has knowledge...
Index D is FAZIT3 with older pin security
Both are prefacelift with same wiring harness.
Thank you Karlos1987, (and others) so I therefore assume I need to go for a H version then to ensure the security issue can easily be resolved ?  OR could  D be used ??  Thanks you.
Umm just my luck  it had to be really difficult !
Edited by andybristol
