The meaning of Llif
Driving on a minor road near Bala in the Principality, we went through what I estimate was about 10 inches of water right across the road for about 40 yards. Loads of the roads around here have flood warnings, but not this one. All was fine, with water splashing all around, including on to the windscreen. Any advice about driving through floodwater (apart from dont) ?
Drive very slow but keep going.
get out and have a good look for surprises lurking in there
create a steady bow wave and stay behind it
Low gear, low speed, and hold constant revs going through. DO NOT lift off because that can draw water up the exhaust pipe.
If possible,keep to the crown of the road where the water is likely to be less deep.
As an addition - if your Yeti is DSG equipped, manually select "1" and stick with it, don't leave it in auto!
 I hadn't thought about it (we don't get many floods up here) but that's probably what I would have done...
Thanks for the advice everyone - I'll know next time.
Carry a pole to test the depth, you should not tackle anything deeper than halfway up your wheels.
My B-in-L driving a new Landrover, started to ford a flooded road and ended up nose down where
the road had washed away.
That is NOT the recommended fording depth of a Yeti!!
Handbook says bottom of the sills.
... and hopefully you keep clear of raised/missing ironwork. I went through what I thought was a puddle in my then new Fabia (swapped when only a few months old for the Yeti) and hit an 8 or 9 inch square drain without a cover which cost me a new tyre. I counted myself lucky though 'cos the wheel was OK. You need to know what's lurking under the surface!
Edited by longedge
I didn't say it was, it is a general rule for the less experienced.
Incidently my sill to the bottom is 11" and the centre of my 17"
wheel is around 13".
I used to work out in the Mendips and one morning (4:45a.m.)
with the rain still stair rodding down I took a sloping l/h bend
out of a village and ran slap bang into a pool of flood water
it was about three cars lengths wide.
I was in 3rd for the bend and just kept my foot at the same
setting and tried to steer for the middle of the road, luckily it
did move over but the wheels had no grip and the car
aquaplaned on its belly pan until the wheels bit and restored
my forward travel to safe roadway. Returning at the end of my shift
the water was almost gone but there was a car still there looking
all forlorn it has obviously hit the big pool of water in the dark but
had not been as lucky.
