Coolant Pump 2 - Failure after Timing Belt Replacement
Hi all
1.6TDI Octavia went in for Timing belt and water pump replacement last week. Car drove fine back from dealership, didnt use it for a couple of days then when hopped in again it went straight into limp mode followed by engine management light. I took it back to garage and they now claim that secondary coolant pump has failed and replacement will cost €350 with the reason being that new water pump installed is more efficient which forced the secondary one to fail. I find this extremely poor excuse and was just curious had anyone experienced similar?
Fault codes as follows:
Address 01: Engine (J623-CAYC)
   Part No SW: 03L 906 023 LP    HW: 03L 906 023 JH
   Component: 1,6l R4 CR td H43 8810
2 Faults Found:
9867 - Coolant Pump 2
          P261A 00 [232] - Open Circuit
          MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage: 193501 km
                    Date: 2039.14.01
                    Time: 09:28:15
9870 - Coolant Pump 2
          P261B 00 [096] - Implausible Signal
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 193507 km
                    Date: 2039.14.01
                    Time: 09:34:18
Readiness: 0000 0000
Address 08: Auto HVAC (J255)
   Part No SW: 3T0 907 044 BR
   Component: Climatronic   H19 0606
2 Faults Found:
9474161 - Motor for Defroster Flap
             B1090 71 [009] - Actuator stuck
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 79
                    Mileage: 193514 km
                    Date: 2039.14.01
                    Time: 09:37:19
9481200 - Coolant Pressure
             B10AB F0 [009] - Unknown Error Elaboration
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 31
                    Mileage: 193341 km
                    Date: 2038.14.30
                    Time: 11:56:03
Yes they said its an electric pump and hence the reason I should pay for replacement  as they swear they didn't touch it during maintenance.
