Jammed Passenger side rear door
Dear Briskodians
I have a skoda fabia 2003 1.4l.
The passenger side rear door seems to be jammed.
It doesnt open using the remote and even if i try to open it from inside using the latch it doesnt open.
Any ideas on how can i have it opened. I have managed to open up the plastic panel, rear window and the inside metal panel. But still i am not able to get the lock opened.
Any suggestions?
Many thanks.
cheers, Nebu
You will have to smash the lock up a little, Firstly I dremelled the bottom of the cover off to access the two cogs you can see in the pic below. You turn these to undo the lock, however I found they kept kept springing back when I let go.
The solution for me was pull ( aka prise off with large screwdriver) the rest of the cover off, this released something and I was able to turn the cogs without them returning.
  • 2 years later...
After spending some time with it, i finally gave up. Took it to the dealer and they pinched open the old lock and replaced it with a new one.
