Timing problems
Might be lucky but the only easy way to tell is to remove the tappets and measure the height of the valve tops. A bent one will be further down than a straight one..
That's the first check I do. Probly find those new followers are dead now if your lucky
I take it you managed to get the locking pins in correctly afterwards by just turning the engine over 180°
Taken the rocker off and one of the followers has smashed to pieces..
There you go then just hope the valve is ok now
It idled okay with no vibrations ect so we can hope!
Get all the followers out and measure the valve heights
I use a straight edge across the head and digital vernier but a short straight bar and tape measure would possibly get you close enough. Bear in mind it's put the same stress on all the followers so change them all.
Oops
There's the culprit! Put the old cam and followers back in and all is well!
Lesson learnt! Always double check the timing! I was lucky!
  • Sponsor
No wonder it was noisy! Do all the parts of that seem to be accounted for?
There looks like there could be quite a big chunk missing in that picture doesn't there!
sent from my Galaxy Note 4 using Tapatalk
Oops
I don't suppose you were able to ensure your old followers went back in the way they came out with the old camshaft were you?
You might experience some accelerated wear on the old followers if not as they will have bedded in to each cam lobe. It might not be that obvious at a quick glance.
More to the point why the hell change it in the first place if it's good enough to go back in !??
Hope you replaced the rocker shaft bolts at least
Here is an example of a worn follower I had when I did this job on my car (next to a new dlc coated replacement). It wasn't overly dished but there were slight flat spots becoming evident on the cam lobe pushing on this.
Is this the sort of thing you had OP?
Edit: also from examples I've seen on Google images this is far from "bad" lol.
Edited by AshVrs
I've changed some that had worn right thru the centre so the hydraulic part has come out lol. Yours is on its way tho caught just in time
I put pictures on a few month back (when Ash was asking advice on changing his) of one I done that had worn all the way through, the camshaft basically didn't have a lobe was just round!
Lol I've just been seeing if I can find that picture to add it here for reference!
Did you say that car had done about 200k miles though?
I honestly don't remember the mileage now, was a taxi though.
I didn't manage to unfortunately, but they were in good condition considering its on 133k!
Felica, he had a rough start up and when it was hot and was started up again it winds over before it fires up, my Vrs done the rough start and it was down a worn cam and cracked tappet
So he thought his was the same and after me inspecting it and saying it was good be still insisted on me fitting the new cam ect..
Yep the set cam with new bolts.
