Webasto telestart T91 / parring / fuse location
I recently bought a SuperB 2010 elegance with a Webasto auxiliary heater installed (from the factory I guess). After months of use the remote (telestart T91) started to flash green quickly for two seconds indicating that the signal was not received by the heater or that the heater is locked.
I have hovered the web to find the right solution to this, first trying to find the Webasto fuse box in the engine compartment - nothing there which is why I assume that the car was born with the heater. I then found that some VAG owners have had luck removing the fuse for the auxiliary heater RC transmitter but in my cars fuse layout there is no indication of a RC transmitter. (info from here: http://www.vwbus.no/forum/viewtopic.php?f=6&t=34670&sid=bc06c7cc6715b16b4dd3bc5371741c38&start=25)
Fuse layout in the dashboard:
No.
Power consumer
1
Diagnostic socket, engine control unit, fuel pump relay, fuel pump con- trol unit
2
Control unit for ABS, ESP, switch for tyre air pressure control, brake sensor
3
Switch and control unit for airbag
4
WIV, parking light, dimming mirrors, pressure sensor, telephone prein- stallation
5
Control unit for headlamp beam adjustment and headlight swivel, con- trol unit for parking aid, control unit for park assist
6
Instrument cluster, control unit for electromechanical power steering, Haldex, selector lever lock, power supply for data bus, AQ250
7
Valve heating, air mass meter
8
Control unit for trailer detection
9
Relay for auxiliary heating
No. Power consumer
10 Adaptive left main headlight
11 Adaptive right main headlight
12 Not assigned
13 Diagnostic socket, light switch, rain sensor, clock
14 Central locking system and bonnet lid
15 Central control unit - interior lights
16 The air conditioning system
17 Not assigned
18 Not assigned
19 Not assigned
20 KESSY
21 KESSY ELV
22 Air blower for Climatronic
23 Front power window, central locking of the front doors
24 Selector lever lock, AQ250
25 Rear window heater, relay for auxiliary heating and ventilation
26 Power socket in the luggage compartment
27
Fuel pump relay,
Fuel pump relay, control unit for fuel pump, injection valves
28 Electric boot lid
29 AQ250
30 Ventilated front seats
31 DVD pre-installation
32 Front power window, central locking system of the rear doors
33 Electric sliding/tilting roof
34 Alarm, spare horn
35 front and rear lighter
36 Headlight cleaning system
37 Front seat heating
38 Heated rear seats
39 Rear window wiper
40 Fan air-conditioning system, relay for auxiliary heating and ventilation
41 Not assigned
No 9, no fuse installed, no 40 no fuse installed. Could it be no 25? Is it okay to just try one out or do I risk anything?
Finally, as noted in this manual from webasto, (http://www.techwebasto.com/redirect/heater_main/907512.pdf) the heater may go into "lockout mode": " After 3 consecutive unsuccessful startup attempts, the heater will lock itself out from any further start attempts."
In one line I dont know what to do, its freezing outside and Im afraid to **** something up.
Hope that one of you bright guys can help me.
Regards from denmark
Have you had any luck with this? I think my heatet also needs a reset. Its so cold I don't want to go outside right now so I haven't checked the fuses yet :-/
Warmed up today so I checked the fuses and behold, a 20A was fried. Changed it and now it works again! [emoji108]
