Amundsen upgrade
Hi all thanks for accepting me to the forum...I have a 2006 octavia ambient 1.9 tdi and just fitted Amundsen sat nav unit to car.all works perfectly phone,sat nav,cd,but seems to be draining battery over night.is there anything I can do to stop it....checked wiring block at back of radio and all the same...help..lol..Skoda dealer didn't really want to know....
I suspect that you'll need an updated Gateway to solve that problem but someone will be along shortly with more details regarding what to do. :thumbup:
Yep, as said it's the fact that the cars Canbus and the new unit are not compatible (they don't talk to each other properly). You need a newer version gateway to make everything speak the same language, and then recode it all to work correctly. It's a weel known issue and has been well documented on the forum if you search for battery drain Columbus (different unit, same problem) you should find the answers you need.
Hi,
i own Amundsen+ and i have maps.
is there any way to get into the car without the original sd card?
Hi my gateway unit is 1ko907530f sw 120 so can I i just get second hand one off ebay 1ko907530 and code in?? Or is there someone on here who can get me one???
