oversized tip
SFS make the intake pipes for R-tech I think. The only differences are that there is an extension so that the MAF is situated closer to the inner wing and, as stated in the description, the small port nearest the MAF has been removed.
So will this fit I have standard airbox setup ?
Unsure on that one. I have a feeling that the extension will put the MAF too far over for the standard airbox. But check with R-tech and they'll point you in the right direction. They are great lads.
