new battery
What is the largest size new battery I can fit to my mk1 VRS?
Last time I checked here people recommended the Varta D15 027 size?
Is there anything bigger that people know will fit?
Not sure, think the tray may be the limiting factor, why do you need a larger one.  The Varta D15 fits and slightly more capacity too.  Taller.  Same as the Bosch S5 005
Edited by Liverpool-Lad
I don't mind spending a wee bit more if it gives me any benefit.
I know you recommend the 027 varta d15 - do you have one fitted?
I have the Bosch S5 005 before I realised the Varta was the same battery!!
I take it you have 027 size?
any reason to consider any other battery than the varta?
Yep 027.  I just bought the most powerful one that would fit.  That seemed to be the one to go for!
ok cheers
fitted and starts first engine crank, on the button now
before it sometimes hesitated for a split second
thanks for advice
btw battery can be had for £52 from battery megastore using discount code 869F9F9833
Cool, glad its sorted.
one related question
how does the car act if the battery is failing ?
Just had mine replaced. Was having occasional problems starting then it didn't even attempt to crank. New battery fitted and problem solved
mine just felt like it was struggling to start some times - especially in colder weather, when the first second or so of starting seemed noticeably slower
  • 4 weeks later...
hi folks just as an aside i have octavia mk1 24v 1.8t which battery is best to fit the 012 or 027 ? apparently both will fit but unsure of whats best cheers
The 027 sized Varta D15 I put in has been superb so far - I'd not hesitate to recommend it.
It is 600CCA and replaced the old one which was 420CCA - no wonder starting is now instant bearing in mind the old one was getting long in the tooth.
I got mine cheapest at battery megastore - discount codes are out there too.
