2006 octavai tdi 5 speed manual
Can any one tell me what is the correct part number for the gearbox oil that i will need going to do a change when the weather picks up also i what to clean up the battery terminals   will i have to have any thing reset when i reconnect it.Just done the rear wash problem with the help of this site it was the pipe behide the cd changer thanks for all the help great site
See here...
http://directskodaparts.co.uk/product/Genuine_Skoda_Manual_Gearbox_Oil_1L_G060726A2_G060726A2#.VqIkViqLTIU
Part number: G060726A2
£6.00 per litre.
Make sure you disconnect the negative terminal first and follow these basic instructions...
http://www.racshop.co.uk/car-battery/how-to-fit-a-battery.html
When you reconnect the battery you will get several warning lights on the dash that will require you to drive the car a short distance before they reset / turn off, so don't panic when the dashboard lights up like a Christmas tree!
Thanks for the helpfull reply
Check whether your gearbox is flat or tilted, if tilted you can't just fill it until it trickles back out the filler.
Sent from my D5803 using Tapatalk
