Would this vw stereo fit?
Hi all would this fit a pre fl octavia vrs
http://www.ebay.co.uk/ulk/itm/172070240210
If so what would I need to do or get ?
Really want Dab radio and trying to do it easy and cheap as poss!
Yes it will fit. You'll more than likely need to change the can gateway if you're car is an early mk2. It doesn't come with Bluetooth as standard so you'll need to get a module, loom and mic aswell.
Not really bothered about Bluetooth just want dab :)
I think I have revision k on my canbus as per the Vcds scan I had done
that looks to be the same shape as the Amundsen, Columbus, so you may need a new fascia depending on what your existing unit is. Some of them are fairly expensive for a bit of plastic (£50+).
Edited by nickgpfc
I do like this part of the advert text:
"IT ALSO COMES FROM GU47 8ND   WITCH MUST BE A BENIFIT"
Nice.  :D
