PD130 KKK Turbo on PD100 ATD HELP!
Now I know this has probably been covered somewhere but I can't find exactly what I'm after.
Basically I'm buying a turbo from Stuart27183 (many thanks to him :) ) this Saturday, and my aim is to fit it the same day in preparation for something happening Sunday. Now I'm happy to give this a go with a mate but I'm not 100% sure on what else I need to buy if anyone could help?
One thing that I'm unsure of is if all of the boost pipes fit?
Anyway, Thanks in Advance,
Sam.
Don't think the boost pipe will fit to the turbo as yours is a push on fitting with a spring clip and the vrs one will have a bayonet type.
Would I be able to buy the boost pipe from a vRS and just fit it?
Sent from my LG-D802 using Tapatalk
You can use original pipe work
If you get a turbo outlet pipe from a vrs Ibiza octy any 1.9 PD with the coupler basically,
gently cut the pressed metal clip off and cut the rubber pipe then you have to buy a silcone 90' degree bend that I believe would you need 45mm both sides but just make sure the leg length is 150mm
Then you will be good to use your standard pipe work
I do have some picture as I've just brought everything for my 1.9 tdi atd but I can't post them on here
Is there anywhere I could pick these up from for tomorrow? I know I could try a breakers for the outlet pipe but what about the silicone hose? Cheers dude
Not to sure any turbo outlet pipe from a pd130/150 or later PD105
Also not sure about the silicone bend I brought an ash hose from flebay
Where abouts in the world are you?
I'll have to do some searching then. And sheffield bud!
  • 5 months later...
Had the Turbo on for a few weeks now, If anyone wants to know anything just PM me :)
I wanna know how it took 5 months to fit?
Had loads of other things I needed to sort on the car and just never got round to it
Sent from my LG-H850 using Tapatalk
Did you fit 130 injectors and remap? Are you happy with the result?
How long did it take to remove and replace ?
Didn't fit the injectors, I'll get some at a later date and no remap as of yet as my clutch is on a slippery slide to death haha. Happy so far, picks up a little better
Edited by Woodlogy0
Took me a full day with a fair few breaks and having to run around different places for tools I lacked and a nut not coming off of the downpipe.
Could be done in a few hours I reckon if you're more prepared than I was
