Skoda Superb II Genuine Spare Wheel Kit (205/55/16), VGC- £115
I've recently said goodbye to my Superb II Greenline, hence, my spare wheel kit is up for sale.
My GL was supplied with a foam kit, therefore, from new, I decided to invest in a full size steel wheel kit which I purchased from my local dealer, Starting Worcester.
The wheel has been used twice in the past four years, but has covered only around two hundred miles. There are no cuts or abrasions to the tyre which is a Continental SportContact 2 (205/55/16 94V). Likewise, the steel wheel is unkerbed an indistinguishable from new.
Supplied with the spare wheel is a polystyrene boot well insert which houses the scissor jack, the wheel nut brace and the plastic tool used to remove the plastic wheel nut covers. In addition, Skoda supply a plastic threaded bolt and nut which secures to a metal coupling on the floor of the boot well. This enables the wheel to be secured in position. Lastly, there is a nylon strap with quick release buckle which secure the polystyrene insert/tools to the wheel.
The "50 mph" sticker is only relevant is you're using the spare wheel in conjunction with either 17" or 18' inch wheels. If using with 16" wheels, I see no reason why the limit would apply.
Searching online, the Skoda Shop is selling this same genuine spare kit for £169, therefore, my advertised price of £115 represents good value. Even if you never need to use the spare wheel, it is peace of mind.
I'm based in Worcester, but travel widely across the Midlands and Wales. Whilst I'd prefer the wheel to be collected from my home, I'm not adverse to delivering by mutual consent, subject to my diesel costs being covered.
Incidentally, I've been a member of Briskoda for over ten years.
Please view my other advertisements for a pair of Autosocks (suitable for the spare wheel) and a Skoda boot liner.
I should have stated the wheel code which is 3T0601012FL, while the tool kit is 3T0071108.
The wheel size is 7J x 16 with a ET46 offset and is suitable for any Superb MkII, with the exception of the V6.
  • 3 years later...
Hi, I know its a while since you posted, but do you still have this?
