Do hatch wind deflectors fit the estate.
Several wind deflectors on eBay. Some specify for the estate but are the hatch rear windows the same so I can buy any of them? I'm sure the fronts are the same.
As a matter of curiosity, why would you want to fit wind deflectors to a modern car?
To deflect wind (:
And for ashthetics sometimes. They suit Monte's tbf
Edited by fabiamk2SE
To the OP. They have different part numbers from what i remember.
The fronts are probably the same, but the rears slightly different.
From memory.. :D
Re post #4.
Not a modern car really is it, not even the All new 4th Generation Mk3 Fabia.
Just as they have been since Fabias were first produced.
The water hitting the roof comes right in the windows if they are a little open, like when in the car and trying to not get all steamed up inside,
maybe snowing and you want the windows down a little,
after all the 'Modern' Budget cars are rather prone to getting condensation even when the A/C is being used,
often the inside of the doors have a fair bit of H20 in them until the doors are opened and it gets to run out.
Fronts match rears don't, as far as I am lead to believe!
Thank you. I'll go for some that are advertised specifically for the estate.
