Wing Mirror Glass.....
Is it easy to remove the wing mirror glass(just the glass)from my 2011 Octavia?!
Thank You...
If it's anything like all the other VAG mirrors then it is ever so easy. Try looking for photos to show how the mirror is attached as that will show you what you're up against to put you more at ease with the task.
It's pretty easy.
Push the side of the mirror closest to the car all the way in, you should be able to get your fingers behind the other side and pull it off. There should be two wires for the heating element which will also need removing.
Just like in this video:
