Vrs better brakes....!?
Just wondering what brake upgrades people have done? Seen as standard aren't too great!
I know some people use brackets and the Porsche calipers, but has anyone done any other things?
Also has anyone's touched the rears?
Cheers!
Octavia mk1 or TT mk1
312mm up front and
256mm on rear
Got mine from eBay
Edited by joedemp
Thanks!
No need for spacer blocks I take it?
VW Golf R32 brakes have been done before too.
Sent from my SM-G925F using Tapatalk
I have a 312mm set up, soon to be replaced by a 330mm set up (the 330 is serious overkill, but, what can you do)
how much power does your monte have ?! :o;)
Mk4 golf r32 brakes on mine.
Twin pot with 334mm two piece disc
Are any of the bigger discs a straight swap? So no need to replace or modify anything to get them on?
Would aftermarket centre discs be better than standard ones of the next size up?
the r32 ones are a straight swap and no need for spacers too but need 17s minimum
11053515_1077485862278078_8670619062785312509608_1722731817961015_39074620645805 straight swap
Nice. Are they Tarox discs? Same size as the standard ones? Would you have a link at all?
Thanks, I've got the gigaros on so should be ok. I'll have a look on eBay and see what I can find.
323 mm setup . lemme see if i can find a link
there you go http://www.tarox.co.uk/product/tarox-brake-kit-volkswagen-polo-6r-all-models-with-288mm-discs-sports-compact-kmvw0986/
other colors then black will cost you 200 extra
will fit with standarts with spacers
Edited by fabianoh5n1
Just standard, if I started to modify the engine the wife definitely would divorce me
Hmmmmm, decisions decisions now....!?
Time to trawl eBay for r32 bits me thinks!
Thanks again everyone!
Make sure to get MK4 R32 brakes.
Sorry for hijacking your thread mate!
No worries mate! Looks like we've been after the same info anyway.
Just let me know when you've found someone doing buy one get one free on r32 calipers ;)
Hi,
Just wondering as i am looking at just putting upgraded discs and pads into original calipers until i invest in other performance upgrades. what are the original calipers in the VRS 1.4 TSI, TRW, Girling, ATE?? Thanks
ATE on the VRS. I wouldn't bother with "upgraded" standard size discs. Just lots of money for minimal heat dissipation advantage from drilled/grooved pattern.
Money better spent on better pads, either EBC Yellow Stuff or Ferodo DS Range
  • 4 months later...
Well it's a while ago but I've finally done it...
Got mk4 r32 front brakes to put on the car!
I just need to get a 17" wheel for my spare!!
