Octavia head rests
Anyone know how to remove front head rests from 2016 Octavia?
  • Administrators
Not specifically, but most new cars have the latch lock (for height) on the last bit of the legs too. So if they were pulled up too far they would not pop out, unless purposefully, press latch in and pull?
But I'm guessing!
This video shows the method for rear seats (from 4:00) probably the fronts are the same.
Edited by aki78
On the rears you have to push the key blade into a hole on the leg without the adjustment button. Its funny as on the Golf its the same but a recessed button you can push with your fingers...no key required.
Not sure if the fronts are the same, quite probably are but never had the need to remove them.
Would be nice if the rear centre headrest could be raised higher at times
