Forge 008 AUQ 1.8T Correct orientation?
Hi is this the correct orientation for the Forge 008 Recirculation valve?
I've been having problems with my car (CODE 17705) where it's been putting on limp mode. I've checked for all obvious boost leaks and haven't found anything, I've unplugged my n75 to check the wastegate and it sits at a constant 5.5psi and I've also cleaned the throttle body today which also hasn't made a difference.
Thanks in advance
