what size is the dumpvalve hose in mm the one on the top of the dumpvalve
That explains it then, on later revisions of the engine the DV was solenoid controlled, I take it yours is just tapped off straight from the inlet manifold
thats correct :)
mine is from 2001 is mine solenoid controlled
EDIT: sorry, misread your post.
Follow the pipework, if it goes straight to the manifold its not solenoid controlled, if it goes to a solenoid it will be controlled via N249
If you have a SAI pump then its probably not solenoid controlled. I'm not sure if they were all like that on the Octy. I know in the TT there was the older engine with SAI and the later one which I had did not have the SAI pump and also had variable valve timing and a few other bits on it and i presume this is when they added the N249 aswell
Edited by SuperbTWM
maybe that makes some difference.... maybe they were different specs sold in different countries.... the mark I vRS in India was 150bhp for example to cope with the fuel....
That bottom pipe in my picture goes straight to the manifold. I have the SAI mapped out too :)
Edited by sharkrider
Okeej mine has the sai pump
aah okeej where on the intake manifold is it connected i guess maybe thats why it works better on your car
