Tfsi help needed please.
I have a few problems with my vrs tfsi - they are below along with the vcds scan. I really need some help please on how to tackle them and in what order.
1. It had a faulty abs sensor (rear right) thats been changed and the fault has gone but I have 01314 - Engine Control Module 013 - Check DTC Memory - what is this and where do I check it. I can't find DTS in the Engine Control Module, What do I need to do please?
2. 000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage
Faulty MAF or wiring? wiring looks fine right back to ecu (ugh that evil anti tamper cage)
3. 00778 - Steering Angle Sensor (G85)
000 - -
Does this need to be basic programed, after a cruise control stalk was fitted? Will it program with the above faults showing?
00120 - Outside Warning Light/Door exit Light Driver Side
012 - Electrical Fault in Circuit
Not a real issue, but if its a common fault it would be good to put it right after the rest.
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1Z0 907 115 A HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0040
Revision: 5BH16--- Serial number: SKZ7Z0F3974071
Coding: 0203000318070160
Shop #: WSC 28050 210 92292
VCID: 336F0115522E491
1 Fault Found:
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Mileage: 252710 km
Time Indication: 0
Date: 2000.00.00
Time: 21:04:02
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 67.0∞C
Temperature: 26.0∞C
Absolute Pres.: 1020.0 mbar
Voltage: 12.192 V
Readiness: 0110 0101
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004738
Shop #: WSC 73430 790 00000
VCID: 73EFC11512AE091
1 Fault Found:
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1Z0 907 044 H
Component: ClimatronicPQ35 084 0305
Shop #: WSC 00000 000 00000
VCID: 3B7F29357A7E811
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004665283
Coding: 018C0F030004140000110D000000000000087F075C0000
VCID: 6CDDDA694F90D69
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 281106 022 0601
Coding: 00055223
Shop #: WSC 73430
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD0YE81K
Coding: 0020788
VCID: 3D7B272D646A8F1
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenks‰ulenmodul 036 0070
Coding: 0000042
VCID: 74EDC20917A00E9
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 912 C HW: 1Z0 920 912 C
Component: KOMBIINSTRUMENT VD1 1610
Revision: V1610056 Serial number: SKZ7Z0F3974071
Coding: 0003401
Shop #: WSC 28050 576 92292
VCID: 356B3F0D5C5A571
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0020
Revision: H04 02 Serial number: 030107F2001673
Coding: 3D3F074007001303
VCID: 2F670D65BE066D1
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VD1 1610
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 005 0954
Coding: 0000756
VCID: 387536394B48AA9
1 Fault Found:
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.074 H07 1806
Shop #: WSC 02069 000 90108
1 Fault Found:
000 - -
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 99801A085283007F3F04850540085F96907CA0
VCID: 830F11D5C20EB91
Subsystem 5 - Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 73430
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000756
VCID: 3973333D7042B31
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C
Component: Radio FO3 019 0034
Revision: 00019000 Serial number: SKZ7Z3G0125385
Coding: 0000402
VCID: 2E591061B90C649
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 005 0907
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 377735054656A51
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
Address 76: Park Assist Labels: 1Z0-919-283.lbl
Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B
Component: Parkhilfe 4-Kan H04 0020
Coding: 0000001
End ---------------------------------------------------------------------
