Favorit Torque Settings
Sorry, me again,
Anyone know what the torque setting is for the lower balljoint pinch bolt on the Favorit? I know it's originally riveted, but mine had already been drilled out and bolted.
I have searched the forum with no luck and Google. The Haynes manual says "tighten to correct torque setting - see illustration" and then gives no setting. I have found some torque ratings in the manual, but it's not a very exhaustive list.
What have I missed?
TIA
Jonny
See PM.
Thanks. It's the one that holds the ball joint into the hub that I need.
Then of course there's the other ones in the same job, hub nut and trackrod. I've tightened them for now, but wouldn't want to mess it up and have it come apart at 60mph!
PM'd reply!
Brilliant. Thanks very much.
