2007 Octavia VRS TDI Bizarre Front Wiper Problems.
Hi all,
Proud owner of a 2007 Octavia VRS TDI that has suddenly developed a weird fault with the front windscreen wipers, I have searched the forums for info but came up blank.
The problem started 3 days ago & is a real weird one, when the engine gets up to operating temperature the front wipers start going by themselves sometimes even varying in speed, the switch has no effect & even when I switch the engine off, remove the keys & lock the cat they keep operating even for upto 15 minutes afterwards, once they stop they will not switch on again with the stalk until the vehicle has sat for a period of time.
I have scanned the car with vcds & found no faults & their is nothing installed on the car that should not be.
Any ideas?
Barry
Your car is equipped with rain sensor that operates the wipers due to any vibrations hitting the front glass try to check the rain sensor for any faults.
Edited by walidhosny
Never heard of a rain sensor that functions by detecting vibrations, are you sure it's not internal reflection based?
That's what I thought too. Also it's unlikely a vRS has the RLS as it was not standard fit in the UK.
Sent from my D5803 using Tapatalk
If the rain sensor is active the wipers will begin moving when street sand hits the front glass or if you hit with your thumb on the front glass.
By that thinking then I water was to run down the screen, say from the roof, there would be no vibration and so the wipers would not operate. This is not the case. Also I can't see that they would work in a light drizzle, or driving at speed would cause more than enough vibration to trigger the wipers.
They work by a light prism. Water effects the lights direction in the sensor so it activates the wipers.
To me it sounds like a faulty wiper motor.
Thanks everyone for the help, car is fitted with auto wipers but still happens with sensor disconnected, have a new wiper motor on order, fingers crossed that it sorts the problem, just odd that it only happens when engine is up to temperature.
I've had some unusualness on a previous car when the wiper motor relay began to fail
Hope the motor sorts it but if not that would be where I'd look next :)
Do the wipers have a relay? I thought they were controlled by the body control module.
Edited by fireman8109
They will be controlled by the BCM but a high current component like a motor usually has a relay to protect the BCM internals
A *very* quick Google search would lead me to believe that there is a physical relay, but don't quote me on that 100% :)
Looking at the wiring diagrams, there is no relay for the front wiper. If there is, it'll be inside the wiper unit and not replaceable.
It has a feed directly from the battery via a 30a fuse and earth. There is also a LIN bus connection back to the BCM which will be used for diagnostics and controlling the wipers.
As you have VCDS, it might be worth looking to see if the wiper motor is visible (should be a subsystem under the BCM) and if there are any measuring blocks to see why it's turned on. As Tech1e says, it's probably a broken wiper unit.
I stand corrected :D
The thread I'd dug up was for rear wiper
Slightly off topic but where did you source the wiring diagrams?  Always useful to have... ;)
The best source is https://erwin.skoda-auto.cz - they charge for access but should give you access to everything you need. A 'print to pdf' plugin is very useful :)
Just a quick update, changed the wiper motor today & the the problem still exists, starting to think that I have a faulty cem, can I just fit a used one (same part number etc) or would I need a new one?
I'd get it on VCDS and see if the switch is activating it or if the central electrics control unit is doing it on its own.
2007 car doesn't have a BCM as such.
I have only just purchased vcds, could you please offer any advice on how to carry out such a test.
Barry
Hi,
The problem happened again today & I finally managed to get some fault codes through vcds, these are shown below, any ideas?
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C8 937 049 AC    HW: 3C8 937 049 AC
   Component: Bordnetz-SG     H64 3205
   Revision: 00H64000    Serial number: 00000006052575
   Coding: E1880F030004140000110D000000000000087F075C000000000000000000
   Shop #: WSC 00568 210 01865
   VCID: 72EBBDBF6DAAE5AE78-8026
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 210909 022  0601
   Coding: 00055223
   Shop #: WSC 00568
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS     300610 054  0403
   Coding: 00209069
   Shop #: WSC 00568
3 Faults Found:
02071 - Local Databus
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 31
                    Mileage: 247438 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 14.35 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01520 - Rain and Light Recognition Sensor (G397)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 31
                    Mileage: 247438 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 14.35 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
00153 - Windshield Wiper Motor;  Driver Side (V216)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 31
                    Mileage: 247438 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 14.35 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
Also to cap it off my can gateway has suddenly given the fault below.
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 150607F2001731
   Coding: E9807F060002021303
   Shop #: WSC 17029 210 94688
   VCID: 306F77B7A32697BECE-8064
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 9
                    Reset counter: 255
                    Mileage: 247433 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:37:11
