lambda oxygen sensors
hello
are these the oxygen sensors I need for my skoda octavia mk1 2003 ambiente hatchback
http://www.ebay.co.uk/itm/AUDI-A3-Lambda-Sensor-4-terminal-0258010032-Bosch-New-/331787495607?hash=item4d401368b7:g:95AAAOSwKtVWzlZK
AUDI A3 Lambda Sensor 4 terminal 0258010032 Bosch New
http://www.ebay.ie/itm/New-Bosch-Lambda-Sensor-Oxygen-Sensor-5-terminal-for-Audi-Skoda-VW-0258007355-/400878476382?hash=item5d56381c5e
New Bosch Lambda Sensor Oxygen Sensor 5 terminal for Audi Skoda VW 0258007355
does anybody know if these are the right numbers for these parts?
0258010032
0258007355
  • Sponsor
You need to tell us which engine your car has, before anyone can really help. What size engine? Engine code would be ideal; a 3 or 4-digit letter code on the sticker in the boot and maybe in the front of the service book.
Edited by Wino
this is a 75kw  1.6liter  gasoline engine    102 horse power
I found the engine number it is: BFQ 096001
and the typerecognitionnumber is 643-147
  • Sponsor
As far as I can see, the correct VAG part numbers for your car are the two ringed in green here:
Info taken from this page.
English language version here.
You may be able to cross-reference from those VAG part numbers to the Bosch numbers you've found using Ebay listings etc.?
Good luck. :)
Edited by Wino
what about the vrs 18.t? mk1
  • Sponsor
Tell me the engine code and year and I can try to look up the sensor part numbers for you, if that's what you're asking?
