Noise from Vacuum Solenoid Block
(The black plastic box on the bulkhead with 7 vacuum pipes connected to it)
From Darkside developments site:
‘Common symptoms of failure are boost issues, EGR /Emissions faults or a buzzing/vibrating noise coming from under the bonnet.’
I am experiencing boost issues –much improved with recon turbo but not quite 100%. I have been aware of this box occasionally making a noise since I got the car 4 years ago (although only recently realised that this was where it was coming from) Only notice the noise after switch off but this may just be because I would struggle to hear it over engine running.
What is your experience of this or take on this? Particularly as some other sources suggest a noise from the Vacuum Solenoid Block is not a problem.
Car: Octavia 2        1.9 PD  BXE
I just replaced mine this week as I didn't like the farting noise when switching off. Its a 5 minute job to replace and £20 from breakers. Its now quiet again although I didn't have any turbo issues.
