White Data Sticker - non towbar owners.
Site .. http://igorweb.org/equidec.aspx
Sticker can be found inside the service plan book or in the boot.
E0A = No special edition
1D4 = Trailer hitch, manually swiveling
7UF = Navigation system - Standard
I8E = Standard radio (Gen2)
1KU = Disc brakes, rear
1AT = Electronic stabilization program (ESP)
7MM = Emission standard EU6 plus
1N3 = Speed-related variable steering assist (Servotronic)
G01 = Front shock absorption
H5C = Tires 215/55 R17 94W
4UP = Drivers and front passenger air bag with knee air bag and front passenger air bag deactivation
L06 = Suspension range 06 installation control only, no requirement forecast
B09 = Type approval Great Britain and NorthernIreland
3QT = 3-point seat belts with tensioner and height adjustment, front
4X3 = Side air bag front with curtain air bag
J2D = Battery 380 A (68 Ah)
QI6 = Service indicator 30,000 km or 2 year ( variable )
8GU = Alternator 140 A
The list is not as comphensive as previous cars missing out colour, seats, core spec etc.. However my main focus is to compare the spec compared to owners who don't have the towbar.
The towbar upgrade cost included the cost of the factory fit, plus upgraded coolant system,upgraded battery and alternator.
I would like to see if these addtional parts are fitted.
Part2 Will be photos of the alternator with part numbers.
Edit.. Not possible to see the part number of the alternator as where the voltage regulator is bolted on to it , it's covered by the block.
Edited by RickTT
here are the codes for my 1.4 act dsg SE-L
JOT = Battery 360 A ( 69 ah )
8GV = Alternator 180 A
Smaller Battery - expected due to petrol over diesel for CCA.
However a bigger alternator ?   (with no towbar)
Would welcome more input from other others.
I think you get bigger alternator with heated windscreen.
Sent from my HTC One M9 using Tapatalk
im still not convinced they provided a bigger battery, alternator and uprated cooling system like it was detailed in the brochure to justify the cost of the factory fit tow bar.
Is that miss-selling or just crap documentation ?
A retro towbar kit costs around £550 all in.
Edited by RickTT
I think the brochure says alternator, battery and cooling are "optimised" for towing. I don't think the parts are actually any different.
I posted a photo of our battery (towbar-equipped car) and I think others without towbar said it was the same type.
On the configurator, it says "Includes preparation of the following vehicle systems for optimised operation whilst towing: alternator, battery, fan and cooling system."  Perhaps that means that those systems work differently on factory towbar equipped cars by means of different ECU settings rather than having different components?  If that's true, and its a bit 'out there' as a guess, it might suggest that recoding after fitting an aftermarket towbar would also 'optimise' those systems.
Mine has a factory towbar too so I can't offer any info on the codes.
Rick... send me the VIN I can find a big list of codes on ETOS :)
Stu
Ok, the white sticker from my 190tdi L&K 4x4 DSG hatch is as follows:
1D0 = Without trailer hitch
7UG = Navigation system - High
I8H = High radio (Gen2)
G04 = Front shock absorption
HI9 = code not found :-(
L08 = Suspension range 08 installation control only, no requirement forecast
You know what.. i think i mis read it as "upgraded"
I have just checked the July 2015 PDF and it does indeed state optimised.
My mistake.
Integrated tow bar The tow bar can be easily released from the boot and folded away after use. Includes preparation
I misunderstood it when we ordered ours - I assumed bigger alternator/battery/radiator.
Don't regret getting the towbar though, it's so simple and well designed.
190 L&K 2WD DSG Hatch no towbar
H19 = Tires 255/45 R19 104Y xl
L07 = Suspension range 07 installation control only, no requirement forecast
4X4 = Side air bag, front and rear with curtain air bag
280 L&K 4x4 DSG Hatch no towbar
1KZ = Disc brakes, rear
1AZ = Electronic stabilization program (ESP)
Odd , the site does not decode my vin
Its Diesel 150/Manual/StartStop no towbar
You don't supply the VIN, just the option codes. These can be found in a sticker under the boot floor or your service book.
My fault,
here you go all equipment of the car:
P.S. The codes are from car production line papers I found inside when it was dropped into dealer. The car is yet in dealer so can't provide the one from boot floor or service book.
3B4 = Child seat anchor for child seat system ISOFIX
1PA = Standard wheel bolts
3CA = Without partition
0EN = Installation differentiation for transmission MQ 350 vehicle components
1Q3 = Mass damper for steering wheel, XXHz
3D6 = Center console
4E2 = Tailgate/trunk lid release from inside (electrically)
4F2 = Central locking system "Keyless Entry"
5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
5J0 = Without rear spoiler
5K7 = Transport protection film (minimum protection) with additional transport protection measures
6XT = Exterior mirrors: with memory function, automatically dimming, electrically foldable/adjustable, separately heated
UH2 = Parking brake
7AL = Anti-theft alarm system, passenger compartment control, backup horn and towing protection
8K3 = Separate daytime running lights with low beam assistant and "Coming Home" feature
8ZQ = Antenna for FM reception only, diversity
9JC = Smoking package
9M0 = Without auxiliary/parking heater
9P5 = Seat belt reminder, optical and acousticelectric contact
K8B = Notchback
VF0 = Standard pedal cluster
VL1 = Extended pedestrian protection measures
0F5 = Fuel system for diesel engine
0G4 = Cable gearshift
VC0 = W/o remote-controlled garage door opener
IA0 = Without bracket
0FA = Standard manufacturing sequence
1SK = Additional engine and transmission guardand underbody stone guard
1S1 = Tool kit and jack
3FA = Without roof insert (standard roof)
3GA = Without cargo area
3G0 = Without child seat anchor front (ISOFIX)
4GF = Windshield in heat-insulating glass
4KF = Side windows in heat-insulating glass, from B-pillar and rear window dark tinted
4LC = Radio and telephone controls
EF1 = ECO function
5RQ = Right exterior mirror: convex
5SJ = Left exterior mirror: convex
7E6 = Electric auxiliary air heater
7KQ = Vehicle class differentiation 601/602
8M0 = W/o rear window wiper and washer system
8N6 = Windshield wiper intermittent control with light/rain sensor
9S6 = Multi-function display/on-board computer"Colour"
9TD = Door warning lights front and reflectorsrear
9T1 = Heated washer nozzles, front
L0L = Left-hand drive vehicle
L30 = Suspension range 30 installation control only, no requirement forecast
0SC = Labels/plates in English
0XG = Information kit in Bulgarian
KS0 = Without head-up display
20A = code not found :-(
QK1 = Camera and/or distance sensor (driver assistance system)
0P0 = Rear exhaust tailpipe (standard)
SM1 = Bodywork manufacturer ENGESIG
0TD = Front and rear floor mats
0YC = Weight range 3 installation control only, no requirement forecast
0Y1 = Standard climatic zones
1EE = Special identification plate
1E0 = Without activated charcoal canister
1G4 = Space-saving spare wheel
UC7 = Rear shock absorption, chassis with increased ride height
1ZA = Disc brakes, front
1NL = Covers for alloy wheels
1VG = Installation parts for four-cylinder engine
1X0 = Front wheel drive
1Z0 = Initial standard fuel filling
2A0 = Without delivery equipment
2G5 = Filler neck module 1 without insert
2JV = Body-colored bumpers
0K0 = Without alternative drive module
3PH = Electric seat adjustment with memory system left, right seat mechanically height-adjustable
3NU = Rear seat bench unsplit, backrest split folding with center armrest
3N2 = Stowage box with cover in luggage boot side panel
3T2 = Three rear headrests
3U3 = Luggage compartment cover with luggage net
3W6 = Additional interior noise suppression
3X0 = Without load-through provision
3Y3 = Roll-up sun screen for rear window and rear side windows
3ZU = 3-point seat belts, outer rear with ECE label
4A3 = Seat heater for front seats separately controlled
4L6 = Breakaway interior rear view mirror, automatically dimming
6K0 = without Front Assist/without city automatic emergency braking
1Y3 = Differential lock (XDS) dynamic traction control
4ZB = Bright moldings
5XH = Sun visors with illuminated vanity mirror on drivers and front seat passengers side
6A0 = Without fire extinguisher
6E3 = Front center armrest
7W0 = Without extended safety system
6M3 = Trunk net
6N0 = Without mud flaps
6Q2 = Leather gearshift knob/handle
6T5 = Interior light in footwell front and rear
7L6 = Start/stop system with regenerative braking
7M3 = Scuff plates in door apertures
7P7 = Electrically adjustable lumbar support for left front seat
7X2 = Park distance control, front and rear
7Y9 = code not found :-(
8IP = Gas discharge headlights with variable light distribution
8FA = Without second battery
8Q5 = Headlight-range adjustment, automatic/ dynamic with dynamic bending light (AFS 1)
8TB = Rear fog light
8T6 = Cruise control system plus speed limiter
8WH = Front fog lamp and cornering lamp
8X1 = Headlight washer system
8Y1 = Two-tone horn
8Z5 = Not hot country
KH7 = Climatronic (3-zone)
9E3 = Luggage compartment lighting
9HA = Without additional malfunction display
9WT = code not found :-(
9IF = code not found :-(
A8D = Luxury equipment
B42 = Special requirements Bulgaria
B0A = Component parts set without country-specific design requirement
C6U = Alloy wheels 7J x 17
C00 = Operating permit, initial registration
FB0 = Standard paint coating
G0K = 6-speed manual transmission
G03 = Front shock absorption
N2S = Alcantara seat covering
1A0 = Fuel system (conversion to gas possible)
QG1 = Service interval prolongation
QJ3 = Chrome package (type 2)
QN2 = Drawer under right front seat
QV0 = W/o TV reception/digital radio reception
Q2J = Comfort front seats
TR1 = 4-cylinder diesel engine 2.0 L unit 04L.A
UI2 = code not found :-(
UG1 = Hill hold control
U5A = Instrument insert, km/h speedometer
2PU = Leather trimmed multi-function sports steering wheel
3LC = Door and side trim panel in foam film and woven fabric
3S0 = Without roof rails/roof load rack
5MC = Decorative inserts
8RM = 8 speakers (passive)
DN4 = 4-cyl. turbo dies. eng. 2.0 l/110 kW 4V TDI common rail Base engine is TS1/TR1
2B1 = Additional exterior noise suppression
8SP = Taillight assemblies with diodes (LED)
4V0 = Without front passenger seat adjustment from the rear
KA2 = With rear view camera system (type 2)
0M4 = Fuel tank
4H5 = Electrically operated child lock
QR0 = Without compass/traffic sign display/ traffic signs recognition
KK1 = Refrigerant R134a
QQ9 = code not found :-(
ES0 = code not found :-(
8S5 = Two reading lights front
8G3 = Masked high beam
EV0 = code not found :-(
FM0 = Basic equipment variant
ER1 = Regional code " ECE " for radio
NS3 = With umbrella
7ZU = Vehicle class differentiation 3V0
2H5 = Driving profile selection and conventional shock absorber
F0A = No special purpose vehicle, standard equipment
2WA = Without additional tires
3C7 = 3-point seat belt for center rear seat
3H0 = Without backrest release for front seats
5ZF = Front headrests
5C0 = Without special body measures
V0A = Tires w/o specification of tire brand
7B3 = 12-volt socket(s)
77G = code not found :-(
0B5 = Wheelbase
7U0 = Standard engine starter
UK1 = Standard rear seat release
UP9 = Radio-controlled clock
9Z3 = Operating voltage 12 V plus 230 inverter
4D0 = Without seat ventilation/massage seat
6KJ = Radiator grille with chrome-plated strip
EA4 = 2 years subsequent warranty, max. 40000 km
AV1 = Driving on the right
EM0 = Without Rest Assist
EI9 = code not found :-(
QH1 = Voice control
S1G = Control of vehicles w. special conversion/installation in production process
S51 = Control of logistics 2
X4L = National sales program Bulgaria
Edited by Samo78
^ That's excellent information, much more useful than the white sticker!
This information can be found for all our cars via Skoda Erwin (you have to pay for access) along with repair guides, wiring diagrams etc.
  • 4 months later...
Here is my results
5RV = Right exterior mirror: aspherical
1KK = Disc brakes, rear
6FF = Body-colored exterior mirror housings and various add-on parts
3PA = Electric seat adjustment for both front seats with memory system 12-way
1N2 = Power steering electro-hydraulic
H5L = Tires 205/45 R 16 87W xl
4UE = Air bag for driver and front seat passenger
4R2 = Power windows front, mechanical window regulators rear
5KP = 3 separate seats (first row of seats)
4QU = 3-point seat belts front w/ tensioner (electr.) and height adjustment
4A0 = Without seat heater
8L3 = Roof antenna
J0N = Battery 330 A (61 Ah)
8GD = Alternator 90A
6Y0 = Without cruise control warning system
9AP = Climatic air-conditioning system (semi-automatic)
7Q0 = Without navigation device
8UA = Radio with CD player
8QL = Key for locking system with remote control
8X0 = Without headlight washer system
4K3 = Radio remote controlled central locking operated from inside and safe securing
G41 = Front shock absorption
QN1 = Drawer under left front seat
3L3 = Manual height adjustment for front seats
9P3 = Seat belt reminder, electric contact in buckle
Q1A = Standard front seats
7X0 = Without park distance control
9W0 = W/o car phone preparation/installation
8WE = Integrated front fog light
7A0 = Without CD changer/CD player
QG0 = Without service interval prolongation
0GG = Emission standard EU4
3S2 = Black roof rails
