Start/Stop...how it works.
Thanks, a very informative answer. As for the turbo, a very good point. I remember reading some while ago  it is very unwise  for example  when  having done a fair mileage and at good speed on say a motorway and pulling into a petrol station or similar,  to switch the engine off as the turbo is immediately deprived of  lubrication, but  to allow the engine to idle for a short while so as  to let the turbo  adjust to the change in circumstances.
The manual actually warns against it, too. Paraphrasing, it says you should idle the engine for a minute after a long hard run, so that the turbo can cool and adjust before the engine is cut off. Quite ironic that it's impossible to follow this advice with stop/start on the car. :D To be fair the turbo is additionally supplied by running coolant after you cut off the engine, and if you listen at the end of a journey you can hear the pump gently humming away for a few minutes after you've switched off the engine. This, I imagine, makes the issue moot as the car 'cools down' the turbo independently of the engine being on anyway, which ought to prevent any issues with oil burning off in a hot turbo.
Edited to add: BTW I forgot to answer one of your questions earlier. Yes, you can use VCDS to deactivate the stop/start system permanently. To be fair though, I doubt you'd want to after actually trying it. It's useful and does save a fair bit of fuel over time. My last car (a Mazda 6 tourer 2.0 petrol) had a timer that kept track of how long you'd had the engine off using stop/start, and it was showing over 30 hours after a year's driving (12k miles). That's a lot of petrol saved!
Edited by Derv
  • Replies 50
  • Views 9.8k
  • I totally understand why the brake lights stay on with auto hold as the braking system is still engaged etc etc.    The highway code clearly states one should use the parking brake in stationary tra
  • two modes: 1. normal(for me), shut down engine just before stop and start when remove foot from brake if brake pedal touched softly then prevent shut down engine 2. with Autohold activated,  shut
  • If there's someone sitting behind you (especially at night) I would say yes. Sitting at a set of lights that you know aren't changing for a while, for example.
