Instrument panel fuel gauge question
Hello everyone...
Is it anyway to connect the mpi fuel sender in carb instrument panel ?
In my believe there is different circuit between them ,mpi fuel gauge need single resistor to work and carb gauge had two resistor's so any ideas?
No, it's not.
Yes, there are different circuits to measure the fuel quantity and signal low on fuel. Just to have an idea, see below how unbelievably complex the circuit is for Felicia with carburetor. Felicia MPI has an equally complex circuit, but slightly different on sender side.
Correction: both Felicia models use a potentiometer as fuel sender but the value of its resistance is different. The potentiometer in Felicia with carburetor is connected in 3 points in such way that it sends a variable voltage. The potentiometer in Felicia MPI is connected in 2 points and it sends a variable resistance.
What the f**k (O.O)
Why VDO you make all these complication thing's why hhhh
Thank you so much for helpful information's i appreciated ;)
Week ago I make a trick trying to be smarter than VDO I bring a 430 ohm resistor and connect it between blue and brown wires and open ignition switch to make sure if fuel gauge show me empty tank and it's was correct so I connect the third yellow to one of mpi sender wire and other sender wire with blue one the result is when your fuel tank is empty gauge show you up littel bit from half tank so the carburetor fuel gauge is working in mpi sender but with upper half way of the gauge till I visit second hand parts dealer and bring mpi gauge
Edited by Omar Sako
Please try writing shorter sentences. Use a period at the end of a sentence. Use a capital letter at the beginning of a sentence. It is hard to understand the logic in a never ending phrase.
Sorry it's seems my writing skills is very bad next time i well try to fix it
