Sagging rear suspension
Im keen to know more about the lift as it would help with the roads i tow on. Thanks all for advice so far :)
The Kilen/Lesjofors online spring catalogues list the following increased ride height springs for the Octavia MK2 1.9TDI estate FWD.
Increased ride height front springs (Octavia MK2 1.9TDI estate FWD) 1K0411105DL
Length 358mm
Wire Diameter 13.25mm
Number of coil turns 5.75
https://www.autodoc.co.uk/car-parts/oem/1k0411105dl
Increased ride height rear springs (Octavia MK2 1.9TDI estate FWD) 1K0511115CR
Length 380mm
Wire diameter 12.5mm
Number of coil turns 8.35
https://www.autodoc.co.uk/car-parts/oem/1k0511115cr
Increased ride height rear springs (Reinforced version) (Octavia MK2 1.9TDI estate FWD) 1K0511115CS
Length 382mm
Wire diameter 12.75mm
Number of coil turns 8.45
https://www.autodoc.co.uk/car-parts/oem/1k0511115cs
Edited by Carlston
