Help with brake issue.
I have changed a rear caliper and forgot to clamp the flexibility pipe so bled the all the brakes. There is a good pedal until I start the car and the pedal goes to the floor.
Any ideas how to cure this?
You have to bleed the master cylinder first.
Can I do this manually the same as the calipers or do I need a pressure bleeder?
Usually the same way but is much easier with a vacuum bleeder.
I'll give that a try shortly, need half hour head space. Thanks for the advice.
Yep, definitely use a vacuum bleeder.
