Steering wheel faults
Hi
Car running poorly and starting problems (see below)
Did a VCDS scan all well bar these 3 faults -  block 16, 56 and 76.
Had been aware of the rear parking sensor problem and have had poor radio reception in past OK now though, obviously neither of these in any way related to how car runs. Seems unlikely but could the steering column faults be causing this much havoc?
_______________________________________________________________________________________
16-Steering wheel -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 CA    HW: 1K0 953 549 CA
   Component: J0527           051 0101
   Coding: 0000042
   Shop #: WSC 73430 790 00000
   VCID: 73E5AC2D12EC03A673-8026
5 Faults Found:
00576 - Terminal 15
            012 - Electrical Fault in Circuit - Intermittent
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       020 0041
   Revision: 00020000    Serial number: SKZ7Z3H0079772
   Coding: 0000402
   VCID: 2E537D59B94E6E4EDC-807A
1 Fault Found:
00856 - Radio Antenna
            011 - Open Circuit - Intermittent
01548 - Sensor for Parking Aid; Rear Right (G206)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 3
                    Fault Frequency: 74
                    Reset counter: 161
                    Mileage: 140618 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:38:50
_________________________________________________________________________________________________
2008 Octavia 2 1.9 PD BXE
Hi car running poorly despite new turbo
Down on power - only really obvious once fully warmed up.
Most apparent over 2000 rpm, at which point power delivery is not smooth - very jerky.
A bit more of a smokey diesel smell than it used to have.
MPG has dropped by about 10 mpg
This car does not have a DPF - never did.
It has been converted to SMF.
Has had a reconditioned turbo - prior to this was even worse.
EGR valve cleaned, new MAF sensor, new fuel filter.
Torsion value is 0.5 degrees
It all started to go wrong after a service and cam belt change - may or may not be related.
Edited by Octy0GG
