Windows 10 discussion and advice
Got it .... I am not sure this is the case, but in the week will try some variations and see what I come up with. Thanks!
  • Replies 83
  • Views 28.7k
  • Bin Cortana search bar, notification tab/button, all the added games crap in the start bar for starters. Speed up logging in by using a pin or other easy login method (might not be able to if you co
  • Sounds like an issue specifically related to Razer laptops. Not really Microsoft's problem...
  • recently upgraded my main PC from Win 7 32 bit to Win 10 32 bit. CPU, mobo etc is 64 bit capable, in fact I had a copy of Win 7 64 bit running on it. Trying to migrate this Win 10 from 32 bit to 64 bi
Apologies, that's windows 11
I'll get back to you shortly
In win 10 Click on window "start" shows three columns
"most used" which shows most used apps at the top then an alphabetical list below.
"life at a glance" Not sure how that is populated but shows date, weather.
and finally
" play and explore" if you scroll down the alphabetical list on the left for the programs you use most, right click and pin to start, they appear in "play and explore"
@leolito I've been using Classic Shell for years. Is this what you're after? My most recently used programs appear on the left.
Far easier to navigate than the native Win 10 Start button menu IMO
I also use Classic Shell (originally on Windows 10 but now on Windows 11), it's no longer being developed so support is a bit flaky.
IIRC there's a configuration app/program installed into the same folder, worth checking this out.
You can open the Classic Shell settings if you open the program (click on the shell picture)
Edited by Lee01
Lee thanks! You nailed it! My issue is tht  I cannot see the "most recent programs", my list stays blank with only Windows Defender on it. No amount of usage bring any "app" in there. Am I missing something in the settings?
Mine is set as 'Classic with two columns' I think
@leolito type in 'Classic Shell' in the search box if you can find or you may be able to open it if you go into settings.
I succeeded! I changed the settings to 'recent programs' (it was 'frequent programs'). Now it seems fine, will run it for a couple of days and see....
Incidentally, today I received an email labeling me a pervert and preparing myself with a thousand bucks in crypto otherwise my deviances will be exposed ... well at least it got me motivated to change my password, thing that I was delaying ....
  • Lee01 unpinned this topic
