Citigo Door Trim Removal
Can anyone point me in the direction of the correct tool (or tools) for releasing the Citigo door trim poppers? I have a tool that's worked well with all previous cars, but the Citigo has defeated me.
There's a nut at the bottom in the middle, look for the hole, turn the nut until you're able to pull off, don't undo it all the way as you don't need to, I just can't remember if you need to turn it 180 or 90 degrees
Yes, I know about the nut at the bottom, which is clearly annotated in the technical diagram. The problem is that I don't seem to be able to release the poppers and I'm wondering if there is a special type of trim tool for these cars.
I had a friend on here give me a hand on mine, we didn't use any tool, just brute force, I'll send him this way tho so he can input his opinion
Sent from my SM-G920F using Tapatalk
Just pull like kittening crazy
