Front hub carriers all the same?
Hi, quick question for you. I need a new front hub carrier (what I would call an upright. The bit which the strut clamps in to and holds the bearing/hub and steers) for my 1.9D non-abs pick up. I have found a carrier for a 1.3 non-abs. It looks the same, but are they interchangable?
The pickups had bigger bolts for the caliper bracket but no other changes. If you got the caliper carrier with it then all is good. Pickup or car are the same apart from that
So I could surely drill the holes larger on the 'new' hub carrier to suit the pick up brake caliper carrier?
Yes or use the car carrier. Makes no difference really
Super thanks for your advice
Hi there I have a set off pick up hubs and it's true the only difference is the pickups use big bolt abs and cars are small bolt
Thanks, I have got one off the bay.
