First real issue
I've had a few niggles up till now , drivers door needs realignment, CarPlay is temperamental but today my first really annoying issue that I might actually bother to go back to the dealer for..... The bloomin a/c seems intent on randomly deciding to blow out hot air rather than cold. Controls all work normally, fan speed and display shows temp/low but temp doesn't change, just super hot air. Awaiting off the ignition and locking the car cleared it but then it came back later today. Bizarre and annoying as for the first time since owned it I've actually wanted the a/c cold.
I had this, I think, after I had the AC on full heat (to test) and turned the car off.
Then when I turned it on and immediately turned it down to 18 it kept blowing hot.
I turned the dial up to HI and left it for a few seconds, then turned it back to 18 and all worked. Not had the same issue since, but then I haven't turned the car off with AC on HI
Ta, didn't realise others had the same issue. Not reoccurred over the last few days.
