Another window !
HI everyone. We've recently had some problems with the drivers windo. Ive read most of the threads but it doesn't seem to remedy the problem
Windows won't operate from the drivers door switches. The passenger switch and window is fine.
If i hold the key in the lock the window will go down and up . But not via the switches.
Could some one throw some light on it please.
sounds like faulty switches in the drivers door.
I didn't think the Fabia III had convenience closing/opening windows?
Straight to the main dealer to sort out under warranty is the best way forward.
Thanks for the replies i will check the switches. Its an 08 plate so it won't be under warranty . Thanks again.
broken wires in the loom between door and chassis inside the rubber boot?
