Trim Clips, Bungs Etc
Doing a tidy of the Estate and have found various trim clips, screws, etc missing or broken.
So, any idea of part numbers and is it a case of going thru Ebay to find them all?
(Starting at the back and working forward, so one of the bungs in the floor is split and needs replacing together with that metal "star" type clip, side trims have one white clip missing and one broken and the lower plastic cover is missing a screw so after them as well)
Breakers yard and pilfer is the best plan. The bits off any octavia/estate or vag car of that era for that matter should provide what you need. The screws are usually either the tx25 screws that you get in the arch flaps for example or another philips head type, or those plastic caps that screw onto studs. You'll know more what you need so have a ring round breakers yards I would, life's too short to be finding part numbers for those bits, plus you never know what else you might find ;)
Edited by YellowCar
No scrap yards near me allow you to walk around anymore, you tell them what you want and they go get it.
Gone are the days of climbing over and into cars having a look to see what you can find (and slipping off wet bonnets)
Oh right, they have changed a bit in some areas, I can walk round one near me. Anyway try the breaking cars section on here?
Will have them next week via local Dealer.
