Retro fit mfd problem
So I've bought a octavia and it seems it's got a few issues I didn't pick up on when I bought it
Guy said he had the mfd changed and the ecu to get it to work
So I've been driving it and the temp gauge was a little strange going up and down
I put vag com on it and the engine don't show up
The abs ain't registered and a few other things
I think it's cause the new clocks ain't been coded right but I'm not sure
The car runs and drives well
1. What are my options ie they seller don't have the old ecu but might have the clocks
2. Is this fixable and who should I be looking for to do it
3. I've seen a few post mentioning shark performance can fix can they ? And how much
Any help would be good
Probably worth posting an autoscan from VCDS to see what's what :-)
I'll load it up when I get home from work I did save one
Tuesday,17,May,2016,20:59:25:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: TMBEH61Z282022189   License Plate:
Mileage: 202110km-125585mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: TMBEH61Z282022189   Mileage: 202110km/125585miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Not registered 0011
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Not registered 0001
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 EL    HW: 03G 906 018 EL
   Component: R4 2.0l PPD1.2 G    9953
   Revision: --H42---    Serial number: SKZ7Z0G4303463
   Coding: 0000072
   Shop #: WSC 66565 257 00032
   VCID: 73E539471240F386991-8026
No fault code found.
Readiness: N/A
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0023170
   Shop #: WSC 22029 576 92068
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
            000 - -
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1Z0 907 044 R    HW: 1Z0 907 044 R
   Component: ClimatronicPQ35 110 0402
   Revision: 00110021    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 4581B79F0C543D36E75-8010
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000004979737
   Coding: 018A0F130004140000110D000000000000087F065C000000000000000000
   Shop #: WSC 73430 790 00000
   VCID: 71E9334F685CC1966BD-8024
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 031007 022  0601
   Coding: 00055223
   Shop #: WSC 73430
1 Fault Found:
00924 - Relay for Headlamp Cleaning System (J39)
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 18
                    Mileage: 202110 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 14.45 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: Q4 AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0MYZYY
   Coding: 0020788
   VCID: 377DCD5746B85FA6659-8062
   Subsystem 1 - Serial number: 6332MSME3126276CA
   Subsystem 2 - Serial number: 6342MSME33544011-
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 036 0070
   Coding: 0000042
   VCID: 74E73A5B174EF4BE80B-8021
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 942 E    HW: 1Z0 920 942 E
   Component: KOMBIINSTRUMENT VD1 1612
   Revision: V1612036    Serial number: SKZ7Z0G4303463
   Coding: 0003401
   Shop #: WSC 00000 067 57207
   VCID: 3A7BD46375AA42CE9A7-806F
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001055288155
   Coding: 393F0340071303
   Shop #: WSC 73430 790 12345
   VCID: 2A5BE423850AF24EEA7-807F
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 18
                    Mileage: 202110 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:46:08
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1612
1 Fault Found:
00003 - Control Module
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 246501 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:57:48
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         006 1204
   Coding: 0000756
   VCID: 387FCE6B4BA650DE6C3-806D
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 73430 000 90108
   VCID: 3663C05341B2A6AE7EF-8063
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000756
   VCID: 3979CB6F70AC49D693D-806C
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       019 0040
   Revision: 00019000    Serial number: SKZ7Z3G0093740
   Coding: 0000402
   VCID: 2E53E833B9E29E6E36F-807B
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         006 1201
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0000001
   Shop #: WSC 73430 790 08192
   VCID: 3D71DF7F648475F6BF5-8068
End   ---------------------------------------------------------------------
Why not post on Ross Tech forum you will probably get a better answer.
Hope you get sorted
I thought people on here had done the mfd clock change ?
Don't take this as me being rude but how would posting on Ross tech forum help ?
Can you reprogram the clock and ecu with vcd??
I'm a complete noob to all this
Normally when people retrofit maxidot they don't swap the ECU over though as it's not necessary.
Seems something isn't coded correctly perhaps.
I'm trying to figure out how I can solve this problem now car runs fine with no warning lights etc
If I'm honest I thought the maxidot cars were cr engines and my cars a pd engine so I'm unsure how it's even running tbh lol
That's if In fact it's been replaced I'm just going off what the previous owner said to me
He said he bought clocks they wouldn't work then he was told he needed a ecu
He was then told he needed a ecu bridge or something
I have no idea who to even go to to get it recoded or even if it's possible
Or even what my options are
You can get maxidot on any engine, it's just a display.
Sounds like the immobiliser has been bypassed which would follow as your diagnostic shows no communication with it.
I'd try coding gateway correctly first and re scan.
The immo fault is due to the mileage being changed, the eeprom has a checksum error
Ross Tech forum is a place like this,but full of knowledge about vcds and how thing's show up from a scan,also how to fix them.
Also someone local to you that can help a hand.
I've joined Ross tech but I'm not aurthrised to post yet so can't ask yet
I have no idea what coding gateway means
I know you can get maxidot on any engine
What I meant is he said he had to change the ecu also to get the clocks to work as well as getting a ecu bridge
I was presuming he would have got a new ecu to replace and I'm sure after 57 plate the vrs went to the common rail
And I know the maxidots weren't available on there early octavia tdi vrs
The common rail came out in 2009.
Maxidot was available as an option in all Octavia 2 models from 2004 onwards except the base Classic model -- and it can even be retrofitted to those. A good friend of mine has an 06 plate PD TDI VRS,with a factory maxidot -- I was in that car just earlier today.
Changing the ECU on a maxidot retrofit is not necessary at all - I have two Octavia mark 2 PDTDIs, both of which have had maxidot retrofits, and I have not changed the ECU in either. And both show an immobiliser fault in VCDS because of the mileage correction as stated by Eddie-NL above. The immobilisers, however,do work as they should do. The yellow warning light comes on when starting, then goes off when the engine fires up on both original keys,and the engine does not start,and the maxidot displays IMMOBILISER ACTIVE when trying to start with a key blade with no immobiliser chip in it (bought to purely open the door lock should that ever be needed)
Mike
Thanks for clearing that up about the imob and the maxidot
Now I just need to know about about the abs not registered and the engine malfunction 0010
And if I can pay someone to code it in correctly
Think it was mid 2008 as mine is 58 plate with cr170 i have not seen many though.
