bolt-on hubcentric spacers
Lads
I've had a look using the search function but can't see anything that answers my question.
I'm looking for a set of bolt-on spacers. I want to be able to use the original wheel bolts / locking wheel bolts when fitting them so bolt-on is ideal. I know i need at least 15mm on the rear to sit flat on the hub / disc, so 15mm is what i'm going for - and 10mm on the front.
Back in my Punto days i had H&R spacers (Type B from memory) which were 4x100, 20mm thick, hubcentric and used the original wheel bolts but they don't seem to do this style any more.
Can anyone recommend a set that will do the job? I'd rather not get some cheapo ones from eBay as i've seen a set warp on my mate's car and were a nightmare to get off and i'm quite happy to pay a bit more for good quality material.
Can anyone help out with suggestions?
Edited by Kevin_Mc
  • Sponsor
For bolt on most brands will only offer 20mm and above because of the depth needed for the wheel bolts to go into the spacer.
Damian @ DPM Performance
Cheers - that explains it then.
Looks like i'll need to get longer wheel bolts (plus lockers)
Any suggestions on decent ones?
Edited by Kevin_Mc
  • Sponsor
We sell H&R spacers that come with the required bolts. If you wanted locking wheel bolts then companies like McGard offer these direct.
I'll fire you a PM once i get new tyres fitted and am ready to fit the wheels
20mm will be fine on the back (depending on wheel) been using the delta steel ones from eBay for years. No issues as long as you get the ones that are machined to sit flat on the disc.
EA9E7087-F22E-4389-972A-3A3CB22A7290_zps
20mm back and 15mm front.
It's 17" Octavia Spiders going on the car so i think 20mm & 15mm will be too much. There's a user on here posted a pic of his Fabia vRS with the same wheels and the 10 / 15mm combo looked like exactly what i was after.
The picture above looks a bit too wide for me and i think the offset of the Spiders would make them stick out more than that.
Are those 16" steels pictured?
Yes 16" steels
