Antifreeze and Coolant for Skoda Fabia 2004
Dear Expert,
My Fabia has got coolant level just below minimum mark. I have checked the manual and it require G12 plus (Pink) coolant but I cant find the same.
Can I top up with Bluecol U antifreeze from Asda  which is universal antifreeze and coolant.
Please advise.
Thank you
No, you need g12, put the Bluecol in and it will turn your coolant into a brown sludge!
Either dealer or TPS will have what you need in stock!
thank you so much  Kellaway86.
i will get it from the dealer nearby. :)
Surely a little water is also acceptable. But knowing the concentration of the current contents is questionable and most won't be aware?
Halfords sell a G12 equivalent.
Not true, it will make it purple, and it won't turn into sludge either, that's a myth, stop repeating it.
However, a little tap water at this time of year is absolutely fine.
  • Sponsor
Sounds like a good time to have a good look around the engine bay to try to see where the missing coolant went?
