Turbo on its way out?
Was wondering if my turbo is on its way out. Used to start boosting at around 1800 rpm and it now doesn't start boosting at 2500 rpm and there is a little bit more black smoke. Car is 2005 mk1 vrs done 118,000 miles and still on the standard turbo. Any help greatly appreciated
I suspect you more likely have a boost leak ... the extra black smoke is the give way along with needing more rpm's...
Near enough same as mine as said previously it's a boost leak most likely
Mine had similar problems but no black smoke (that i noticed). Turned out to be a bad maf sensor.
