CCM CONVENIENCE UPGRADE
Hello everybody!
I wonder if it is possible the upgrade of ccm convenience (adress 46). My Car is O2 pre-fl
mine 046 is the
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0203
   Revision: 00020000    Serial number: 00000000000000
   Coding: 98801A085283407F3F02050FC0088FD6907E40
   Shop #: WSC 00231 447 72242
   VCID: 032B4353427BBA2663-8056
and i am looking if it is possible to make an upgrade in
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
   Component:    KSG PQ46 ELV 043 0612
   Revision: 00043000    Serial number: VWZCZ000000000
   Coding: 00910A0001860E763604941570084F0B607C01
   Shop #: WSC 05311 000 00000
   VCID: 7AD53EB735B1FBEE30-802E
this ccm is from passat cc 1.8 tsi 2009 with bsg 09 (not bcm)
your opinions please
regards
vv
Out of curiosity, what are you trying to achieve by replacing the CCM?
I think the reason for this is to get the Convenience option in the Facelift Maxidot
Passat CCMs did allow this
I don't think it will work properly
correct my friend this is the reason that i am thinking about doing this.
The NEW my 2010 cluster that i have in my Car do not support comfort menu because of old ccm.
The ways to have this function are 2
1) fl bcm retrofit ( possible but needs a lot of work .......)
2) or trying Auto polar fis module which can open several comfort menu options.
any ideas????
vv
Hmm, the OP says his car is a preFL, so must be around 2008 to have gen 3 locks and the BT module. This already supports the comfort menu in maxidot -- it's what my 08 plate preFL estate had from factory even without a factory maxidot. All the menus show up in the retrofit maxidot.
Mike
FACELIFT CLUSTER is fitted and uses BAP
Polar would be the way to go.As said, the AR module would not work in your car as it is for different door locks from the BT version.
Yes the AR version would open the menus, as it did when I upgraded mine, but with mine, the upgraded and original CCMs came from the same age vehicle with the same type of door locks.
Mike
Tell me something Mike,
when you say upgraded ccm , what you mean?
do you have in your Car latest cluster like me?
is there somewhere that i can buy upgraded bt ccm?
regards
vv
Edited by 4WDDSG6
I installed preFL maxidot in my non maxidot preFL car.  It originally had midline CCM and I upgraded it because my original midline did not give the menus in the new maxidot.
Mike
how you upgrade your ccm?
or you bought another NEW one latest model
vv
the ccm that you bought from ebay, was like the above?
vv
No, I explained above that the car that this was done with is an early (2004) Octavia 2 with gen2 door locks. It originally had a BN version (midline) and I changed it to a AR (highline).  AR or CB versions are both highline and they would both work.
The BT version is for the later preFL Octavias (about 2008) which have gen 3 door locks. A BT version would not work in the above car as the door locks are different, and would not operate the central locking.
The version I bought from ebay is the same AR version that you list in the first post
Mike
If I remember correctly Mike didn't you first try a passat  3C0 AR version and it didn't work properly? before you bought the 1K0 AR version
But 1K0959433AR is older modul than 1K0959433BT that i use , i am confused
vv
Read the posts again.  The AR IS NOT compatible with your BT because the lock controllers are DIFFERENT.
Install AR module and your locks will NOT WORK.
Install Passat module and your locks WILL NOT WORK
can you tell me the exact part Number of ccm that you have now in your Car please?
vv
Same as the one you quote in post 1. I have pre FL cluster in my preFL car so what I have is of no relevance to you with a  FL cluster
correct
vv
Not quite sure what you're trying to say here Mike......... :p :p
OP has a BT version (highline) which doesn't support the BAP protocol needed for a FACELIFT maxidot cluster that he has installed in his preFL car. He asked about changing it for an AR version (highline) in post one, and he has been repeatedly told that the AR/CB versions are not interchangeable with the BT he already has (because BT is for gen 3 locks, AR/CB is for gen 2), and has also been told more than once that the 3C0 Passat module he has mentioned has been tried by myself unsuccessfully. Neither the AR nor the Passat module he wants to change to will work the locks, and he would be better to leave the CCM as it is and use a Polar box to get the maxidot menus he wants. He has also been told more than once that my AR upgrade from a midline module is fine in my car because I don't have a facelift cluster in the car, it is a preFL cluster in a preFL car, so what I have in mine will not work in his -- he's been told, and still he asks the same questions.
Mike
So, you're saying is that what, and how, he wants to do it won't work? Hmmmm, if only that message had been clearer from the start. Oh.....wait.....hang on.......... ;) ;)
  • 6 years later...
Hi, I tried to found what CCM will be suitable for upgrading my Convenience module but I really didn't find a guarantee number for upgrade. The only thing that I want to archive for now is rain closing, but in near future I want to add at least electrical seats to car, so I will need a MAX CCM. In my Skoda octavia 2 2007, I have a CCM with code: 1k0 959 433 CP, the module is with 5 connectors and remote key works with 434hz. I think that the best solution for upgrade will be 1k0 959 433 CR but as I already mentioned, I'm not 100% sure about this. Could you please help me?
Also, do you know how complicated will be to change my 5 connectors CCM with one with 4 connectors?
Thanks a lot!
