Wax on plastic trim.
On my mk3 Monte Carlo I've got wax on the dark grey, unpainted, textured(?) plastic trim bellow numberplate. I thought I'd got rid of it. But I'm still seeing whitened areas where I'm presuming the wax is trapped in the 'texture' of the plastic. If that makes sense?
Anyone recommend best way to remove this, also a good product to use on that type of bodywork trim when detailing car?
If a school rubber doesn't work, try some peanut butter.
Treatment wise, I'd go for a semi permanent coating product. I used Gyeons trim coating with good results on a friends BMW X6. Available at polishedbliss.co.uk
Hope this helps buddy.
I usually use a toothbrush/nail brush and diluted APC (depending on the area) then treat with your chosen plastic gloss/protector :)
As above - the stiff brush technique works pretty well;
especially if the wax has had time to really dry out and go hard.
Failing that - the school eraser trick works well also.
Never tried the peanut butter method as yet....
Let us know how you get on.... :thumbup:
Needs to be smooth peanut butter other wise there will be nuts all over the place
nuts!
What is APC?
All Purpose Cleaner. Meguiars and the like produce it.
What is APC?
Auric's Peanut Crunch
