Errors P2183 & P2185
Had the engine management light appear on my way to work today. Plugged my OBD reader and had two warnings:
P2185 fault
P2183 pending
A little search shows these codes separately towards the coolant temp sensors. Temps for oil and coolant on gauges appear ok (oil around 85-90c depending if I'm sitting in traffic or motorway speeds).
I recently sprayed the car with air con cleaner (Wurth) and been running it on max cold the day before. Could this upset the temp sensors?
If it helps, VRS CR170 diesel, 2011 / 45k miles
  • 4 weeks later...
Coolant sensor replaced by an Indy for £80, running nicely and no bugging light now :-)
