only key locked inside my skoda cotavia mk1
hello there
I managed to forget my only spare key on the passenger seat in my skoda octavia mk1 ambiente
and then when I closed the door it auto locked the vehicle so I can´t get in
do you guys have any ideas how to get in the car without breaking a window?
I´ve heard about some boot entry with some tools you can use?
it´s 2003 model.
I have managed to put a long wire with plastic strap in front on the inside handle on the drivers front door, but when I pull out the handle, nothing happens??
why???
it only locked itself when I closed the door!!
so it shouldn´t be deadlocked
Edited by greeneinar
Autolocking is also dead locking. This is because one of the door micro switches, probably the drivers door, is saying the door is already locked before you closed it. I found this out when I had problems with corrosion of wires in the door wiring plug.
ok the locking event happened in this order:
1. I pushed on the open car button on the key remote
2. all doors got unlocked
3. then I just opened the passenger side front door and put the keys on the chair.
4. then I closed the passenger side front door
5. and then it autolocked and I couldn´t get in
so do you think I can open the door on the passenger side?
would that be deadlocked also?
