Cotton Filter Installation
I'm looking after installing my new Green Panel Filter after receiving one today (:thumbup: JBS :thumbup: ). Are there any how-to's about? (with piccys?) I've done the quiccy search but it came up with nothing...
Ta
[The slippery slope has begun......first a remap now this....who knows what next...]
:thumbup:
Just whip out the standard filter and replace with the Green Filter....job sorted.:thumbup:
:duh: Ah yes.....thats assuming I know how to do a standard one....
Assume I know where the engine is and work from there.... :D
The air box is on the right hand side of the engine behind the battery. Just open it, take out the paper filter, wack in the Green, fasten up the box. That's it.
Can't remember how the box is fastened. Could be clips or screws. Too dark and cold to have a look now ;-) You'll be able to work out what to do once you've got that bonnet open!
there are 2 screws at the back of it and then it just unclips from the front
Yes, two screws.
It was a bit of a fiddle to clip and unclip it, but I was doing it on a dark night, with just a torch for light....
Yes' date=' two screws.
It was a bit of a fiddle to clip and unclip it, but I was doing it on a dark night, with just a torch for light....[/quote']
That sounds like what I'm doing tomorrow night! :D
Thanks for the tips guys. :thumbup:
i seem to have done most of the swaps on mine in the dark too... why is that !?
anyway, as above, 2 screws and tilt the lid towards the front of the car to unclip. it is a little fiddly but you'll be fine.
you may find the green filter sits tight in the tray, dont worry about this, just make sure the cover goes on square and tight and check that it is seated right all the way round. there are instructions in the box with the filter that say you may need to cut the small lugs around some of the edges to make it fit perfectly (they more than likely use the same filter on different makes of car), i didnt have to do this on mine so you shouldnt have to either.
