arb bushes
hi
have read a bit on this but just wanted to double check before ordering
cars 2002 vrs
if i want to replace arb bushes after taking the plastic collars off the bar i need 17mm bushes rite?
Going with 17mm
Yes 17mm without the collars, 19mm with. I have the SuperPro Poly ones.
You may also require the modified clamps if your originals are old enough, the rubbers have been modified a few years ago. A slightly longer bolt is good for starting to close the clamps down too as they are really stiff when they are new.
Good shout Phil, I forgot about the new clamps!
thanks fellas
Was going to replace the clamps too as they are old so the dealer will have the new ones i presume
i was looking at some on vwspares,you think they would be the newer ones to fit the modified rubbers aswel?
http://www.vwspares.co.uk/product_info.php?products_id=2560 thats the bush i was thinking get
http://www.vwspares.co.uk/product_info.php?products_id=263          CLAMP
these be ok you think??
Edited by huwants2no
The clamps look about right, but it's difficult to be 100% without having the old ones to compare against. Can you get a torch in the wheel arch to check yours?, as they are noticeably physically different.
will have a look
Yes those are the new ones you need
Edited by Liverpool-Lad
